Discussion topic: Sky Max router dropping
Message posted on 22 May 2025 12:40 PM
Upgraded to the Sky Max Router as we've recently got rid of sky Q and since then the signal strength has been terrible upstairs, meant to be on 150mbps speed and can barely even get 40mbps in rooms, plus two bars of signal now on our phones. Even drops to less than 20mbps at times.
Thought it would of improved the signal upstairs by paying the extra per month, how do we get the boosters? Can't seem to get a hold of anyone on the chat option.
Message posted on 22 May 2025 01:12 PM
Re: Sky Max router dropping
150mps is what you get to the router
Your sky q box also acted as a booster to your broadband speed
You can call sky and ask for a booster
Message posted on 22 May 2025 01:13 PM
@DaniiM You do not chat to sky about the booster request, you NEED to call them direct and request it then, they do a test with you and if that shows booster is required then one will be sent. Link to all the details are below.
getting sky max and how to get the pod's
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
Message posted on 22 May 2025 03:08 PM
Getting rid of Sky Q likely caused your issue. Sky Q boxes act has hotspots for your broadband so removing them would have reduced your coverage quite significantly.
