Discussion topic: Sky Max Pods Connection issues
This message was authored by: DaveH111
I have 3 Sky Max pods and none will connect over WiFi even after being setup using and ethernet connection.
Any two at a time will connect via ethernet correctly but try and add a the third and it just sits with a flashing white light.
Any two pods will.connect over ethernet so seems its not a pod issue and have factory reset the router and started again but not joy.
I can only think at this point its a router issue but need help
Any ideas?
