Discussion topic: Sky Max Parental Controls
Message posted on 16 Aug 2025 09:41 PM
Hi all , I have the normal black sky router , I am thinking of upgrading to Sky Max for the kids however I wondered are you able to choose what content they can see using the parent controls ? I know you can set limits
Message posted on 16 Aug 2025 09:50 PM - last edited: 16 Aug 2025 09:53 PM
Re: Sky Max Parental Controls
@Plonka86 Have read at the help for parental controls and sky max! Also the BB Shield that you already have now!
Parental controls with Sky WiFi Max | Sky Help | Sky.com | Sky Help | Sky.com
Sky Broadband Shield | Sky Help | Sky.com | Sky Help | Sky.com
Message posted on 16 Aug 2025 09:53 PM
This doesn't answer my question , can you choose what type of content they see on the devices ?
Message posted on 16 Aug 2025 10:07 PM - last edited: 16 Aug 2025 10:16 PM
No, that's not a level of control which any ISP offers. Fine-grain web filtering is time-intensive and consequently expensive to maintain, and so typically sold in subscription format to schools and similar institutions.
Message posted on 17 Aug 2025 07:52 AM
@Plonka86 if you want that level of control it is normally done at device level but Sky's Broadband Shield which works with your current hub can control the type of content to some extent but will affect all devices on the network while active. See https://www.sky.com/help/articles/sky-broadband-shield-start
. The parental controls offered in the Sky WiFi Max bundle are explained here https://www.sky.com/help/articles/sky-wifi-max-parental-controls
