Discussion topic: No wifi on laptop or tv
Message posted on 16 Aug 2025 09:22 PM
The WiFi seems to drop off around 9pm every evening tonight it still hasn't returned.
Message posted on 17 Aug 2025 07:43 AM
Re: No wifi on laptop or tv
@Marcie1982 assuming your hub has not lost connection (see https://www.sky.com/help/articles/hub-lights-explained-start) the issue is probably marginal wifi connection which is getting disrupted by interference from your neighbours' networkrs. The anser id to imptove the wifi signal in your home.
Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
