This discussion topic has been answered Discussion topic: Sky Max No Wifi
Message posted on 19 Sep 2024 04:19 PM
Has anyone else had issues with sky max its was installed on the 18/09/2024 all activated but no Wifi
at all ,contacted sky they say the setup is working and are investigating why no Wifi to display to and connect anyone else having this issue , the router will work with ethernet but not Wifi
Message posted on 19 Sep 2024 07:11 PM
Message posted on 19 Sep 2024 06:43 PM
Re: Sky Max No Wifi
We are having the same issue... the app is saying there is a fault and when we run diagnostics, it tells us that everything is fine but we still can't connect
Message posted on 19 Sep 2024 08:23 PM
Re: Sky Max No Wifi
I have the same issue. I had it installed today and when I search on any of my devices I can't find or connect to it. If I run a check it says everything is fine. Funnily enough, my Sky Glass TV has stopped working too. I can't even turn it on. It's very frustrating.......
Message posted on 20 Sep 2024 03:20 PM
Re: Sky Max No Wifi
Thanks , Yep makes me wonder why I went back to sky broadband and they are as much use as a bunch of frogs
