5
This discussion topic has been answered Discussion topic: Sky Max Hub
This message was authored by: Art+H
Sky Max Hub
My Sky Max Hub was installed in the wrong place and I need to be moved to the right place. How can I do this.
Re: Sky Max Hub
@Art+H
If you are new to the forum then welcome to the Community which is predominantly made up of Sky customers helping other Sky customers. You aren’t actually talking to Sky by posting on here.
Did you not mention it to the engineer when it was set up?
Re: Sky Max Hub
@Art+H
Avatar for Art+H
Re: Sky Max Hub
Yes I did ask for the Sky Max Hub to be installed in a different location but the engineer on the day told me it could not be installed anywhere but the location he choosed. I had a fault with the hub and another engineer arrived and told me that the hub was in a bad location and it should have been installed in the location I initially asked for.
Re: Sky Max Hub
@Art+H
Then you need to contact Sky and request it be moved and inform Sky an engineer has told you this.
Avatar for Art+H
Re: Sky Max Hub
I did ask Sky to move the hub and told them what the engineer said but they want me to pay for the job.
Re: Sky Max Hub
@Art+H that is fairly normal.If you want to dispute that raise a formal complaint using these links How to make a Sky complaint | Sky Help | Sky.com
