Discussion topic: Sky Max Hub
This message was authored by IanD3 This message was authored by: IanD3
Sky Max Hub
Hi, I have recently changed to the Sky Max hub and my printer will not connect to the access point. Any ideas?
Re: Sky Max Hub
@IanD3 it could be thst your printer requires a single band 2.4GHz wifi connection. Sky tell us that the Wifi Max set up does not offer the ability to split the wifi bands that their other hubs do. The possible work round would be to turn off the 5GHz band on the hub which you can do in the app AFAiK connect the printer and then turn the 5GHz band back on and hope it stays connected.
Let us know how you get on.
IanD3
Re: Sky Max Hub
Hi Chirsee,
Msny thanks for your reply. I've turned 5HZ off leaving 2.4HZ however still no connection to the printer. Same messsge, failed to connect to the access point. The previous hub worked fine with it.
Re: Sky Max Hub
Unfortunately the Max Hub is substantially different under the hood to any previous Sky router, and has some issues which Sky are yet to reslove.
This message was authored by KevNewMedia This message was authored by: KevNewMedia
Re: Sky Max Hub
Posted by a Sky employee
Hi @IanD3
Thanks for highlighting this issue.
What's the name and model of your printer?  We recently introduced an option to switch the security from WPA3 to WPA2, can you try this and let us know how you get on?
Kev
Community Manager
IanD3
Re: Sky Max Hub
Hi Kev,
Thanks for this, the printer is a Canon 3500 series. I'm thinking of switching back to the previous router as internet is dropping out a lot.
Re: Sky Max Hub
Thanks @IanD3
I've escalated your post to our Community Messaging team to investigate both issues for you.  They will be in touch over the next 48 hours. Just check back here every now and again. You're looking for the chat bubble in the bottom corner of the thread.
For more information on how the service works, click here https://helpforum.sky.com/t5/Did-you-know/Escalating-a-post-to-a-Sky-expert/ba-p/3711147
Kev
Community Manager
IanD3
Re: Sky Max Hub
Hi Kev, many thanks for your help.
regards
Ian
This message was authored by Addie15 This message was authored by: Addie15
Re: Sky Max Hub
Hi there! Thank you for escalating this. We have sent an invite to IanD3.
