Discussion topic: Sky Max Hub Terrible Connection
Message posted on 17 Apr 2025 10:41 AM
My wifi connection since moving to the Sky Max Hub has been borderline unusable.
The connection constantly drops out across all my devices and the Sky diagnostic tests are telling me I am getting 2-3mb daily average.
Message posted on 17 Apr 2025 10:42 AM
Re: Sky Max Hub Terrible Connection
@Sgreeny93 Poor WiFi coverage is probably the most common question we get in the forum. In many homes a single Sky hub cannot provide a usable wifi signal in every room due to the layout and type of construction of the property especially in older homes with solid internal walls. Assuming the hub is in the best possible position which is out in the open on a surfsce then the only answer is additional wifi sources.
Message posted on 17 Apr 2025 10:44 AM
This is in a small 1 bedroom flat. All rooms are within a few metres of the Hub. I have never had these issues on older Sky routers or with other providers. This has only started happening since 'upgrading' to the Max Hub around a month ago
