Discussion topic: Sky Max Hub Orientation
Message posted on 30 Apr 2025 09:05 PM
This might be a strange question, but does the Sky Max Hub have to be stood up like the picture below or will it also work laying flat on its side, without overheating or any other negative effects
Message posted on 30 Apr 2025 09:10 PM
Re: Sky Max Hub Orientation
@Leonsky Stood up is the way!
Message posted on 30 Apr 2025 09:14 PM
I have always had my hub stood up, as in the photo, mainly because it's in the window now since January of last year after had full fibre to the property fitted and had the optical network terminal box put in the living room and also because your password is on the bottom of the hub
Message posted on 30 Apr 2025 09:31 PM
That wouldn't be the orientation around which the layout of the internal WiFi antenna array was designed.
Message posted on 30 Apr 2025 09:38 PM
My cats were forever knocking it over onto its front and it would cripple the WiFi
