Discussion topic: Sky MTU 1534?
This message was authored by TrebleTA This message was authored by: TrebleTA
Sky MTU 1534?
So I've noticed that you can set the Sky's MTU to 1534, is this a glitch?
Also doing a DNS check, I've noticed 1-2 of these sites that also report MTU say its 1486?
It's set at the default 1500, but its how I noticed the above.
Sky FTTP, SR203 hub self bridged to Asus AX82U. Sky Q UHD to Samsung QE55S95BAYXXU , Sky Q Mini.
Re: Sky MTU 1534?
@TrebleTA
MTU - Maximum Transmission Unit is set to 1500 allowing devices to select up to that value. My series x xbox selects 1492 . A value higher than that could be a glitch and may affect the size that the packets are received im. @mae-3 may understand the repercussions better than me
This message was authored by mae-3 This message was authored by: mae-3
Re: Sky MTU 1534?
@TrebleTA
The packet sizes greater than the gateway attached will cause fragmentation, this will be seen as speed reduction and packet loss. It must be set to 1500 being the most common size across all networks.
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
TrebleTA
Re: Sky MTU 1534?
I thought it should not go over 1500 so strange, I have tried 1534 and have 0% packet loss. Also why are sites reporting that skys MTU is 1486 when I've set 1500 or 1534?
Re: Sky MTU 1534?
@TrebleTA
Can you see any increase in performance or any impact using 1534, it is likely being set upstream to 1500 anyway so any different setting won't make any difference with Sky Hub. The network is 1486 on some older networks and 1500 on almost every network in the world.
TrebleTA
Re: Sky MTU 1534?
So I tested via ping for the mtu, mine is 1472, then plus 28 so 1500.
But it's the fact skys device can go over 1500 so its a glitch.
Thanks for the advice
