Discussion topic: Sky ID
Message posted on 29 Nov 2025 08:26 PM
Sky ID
Where don't find this ?
Message posted on 29 Nov 2025 08:55 PM
Re: Sky ID
@Georgina1975 Not easy to work out what you want or need so here is the help maybe you can work it out!
Message posted on 29 Nov 2025 08:59 PM
Re: Sky ID
Hi Sky not working but app states puck issue
Message posted on 29 Nov 2025 09:03 PM - last edited: 29 Nov 2025 09:05 PM
Re: Sky ID
@Georgina1975 Are you aware that this is not sky Customer Service when you post on the Forum?
This link below provides information about the coloured lights on the various hubs that can help to see what is going on! If the system is also Full Fibre then the lights on the OR/CF ONT also require to be looked at!
and or below
If you haven’t done it already use the below link to check to see if there are any broadband problems or outages nearby if enough time has passed for a fault condition to be displayed by the software test! This should determine if there's an identified fault affecting multiple households.
