Discussion topic: Sky Hub Max Red X for Ethernet on At a Glance page
Message posted on 09 Oct 2024 12:54 PM
I reciently got Sky broadband with a Max hub.
On the "At a Glance" page I often see a red X next to Ethernet in the Home Network section.
Can anyone advise what this actually means? I cannot find anyhing in the logs or any documentation for the web interface to indicate what the issue could be.
Message posted on 09 Oct 2024 01:12 PM
Re: Sky Hub Max Red X for Ethernet on At a Glance page
@Jimbo5000 do you have anything attached to the Ethernet ports on your Sky hub?
Message posted on 09 Oct 2024 01:49 PM
Yes - lots a quite a few devices through unmanaged switches.
All seem to be communicating ok (incuding the PC im using to respond to this).
And I see them in the device lists and seem to be getting IP addresses without issue.
When I reboot the hub it does appear as a green tick, but sometime later goes red.
I've never seen it go back without a reboot of the hub.
Message posted on 09 Oct 2024 02:26 PM
@Jimbo5000 not 100% sure but the way Sky determine what is connected seems quite buggy - it neverscgets my devices quite right - so I wouldn't worry.
