Discussion topic: Sky Hub 6.0 not compatible with Canon printer !!
Message posted on 06 Jun 2024 08:17 PM
Having had Sky Q for years, recently I switched to Sky Stream and now thje two canon printers that worked with SkyHub 4.0 do not work with Sky Hub 6.0 WHY!
Canon PixmaMG3650S bought from Amazon in June 2023
Message posted on 06 Jun 2024 08:31 PM
Re: Sky Hub 6.0 not compatible with Canon printer !!
@Slimnot47 Your post has been moved from the Sky Stream forum as this isn't a stream puck related issue.
Message posted on 06 Jun 2024 09:02 PM
One possibility is that the printer doesn't like the WPA3 encryption which the Max Hub uses by default.
You could try changing this to WPA2 in the Hub settings section of the My Sky app.
