2
This discussion topic has been answered Discussion topic: Sky Hub 4.2
This message was authored by: Weston+Boy
Sky Hub 4.2
It says not to install until the date on the box.   There is no date so can I install it straight away?
Re: Sky Hub 4.2
Was this a replacement for an older hub, if so yes you can install is as soon as you want.
Re: Sky Hub 4.2
Avatar for Weston+Boy
Re: Sky Hub 4.2
Yes it is. Thank you for your reply.
