5
This discussion topic has been answered Discussion topic: Sky Full Fibre Install
This message was authored by: RK11
Hello. My Sky full fibre installation date was due on the 19th of June but it was saying that there was an issue with the order and they told me to contact sky directly in order to get the order back on track. I have tried calling them, but when they ask for the two digits of my bank account, it doesn't proceed forward. Now, the new installation date is in August and I wanted to know if somebody can reschedule the meeting with the engineer.
Re: Sky Full Fibre Install
@RK11
'UG congested duct' is the key information: that implies digging is required, which is the most likely reason for substantial rescheduling.
Typically the issue with full fibre installation is either infrastructure, equipment or personnel availablity.
If it's in the UK then putting the address into the BT Wholesale Availability Checker should indicate which provisioning type is applicable.
Avatar for RK11
I have attached the image with the table and the two most important lines.
@RK11
Could you post the first few lines of text below the table?
Avatar for RK11
@RK11
