Discussion topic: Sky Full Fiber External Work
Message posted on 20 Jan 2025 11:37 AM
Hey,
I've got a Sky Engineer coming to activate my full fiber broadband on the 27th, however I've not yet had the external work completed by OpenReach.
Is the external work normally completed more in advance or are they normally quite close together. I'm worried about the Sky engineer turning up on activation day and they won't be able to do their work.
Message posted on 20 Jan 2025 11:39 AM
Re: Sky Full Fiber External Work
Enter your full address below and post the table and notes after removing your address from the image
Message posted on 20 Jan 2025 11:43 AM
Thank you.
Message posted on 20 Jan 2025 11:50 AM
The issue is the underground congested duct ie they may do the internal work first but may have to rearrange a visit to sort out the duct if they can't rod and rope the fibre through. Other than that both can be done on the same day
Message posted on 20 Jan 2025 12:00 PM
Will the Sky Enginner do both? I was told that someone from OpenReach would come first to do the external work and then the Sky engineer would come first to do the internal work.
I've got a date for the Sky engineer but nothing for OpenReach.
Message posted on 20 Jan 2025 12:01 PM - last edited: 20 Jan 2025 12:02 PM
Unfortunately if Openreach hasn't got the drop cable from the local CBT to the external CSP enclosure, there's not a lot a Sky installer can do because the main part of their job is to fusion spliced an optical pigtail onto one strand of the drop cable and run this to the internal ONT.
Message posted on 20 Jan 2025 12:02 PM - last edited: 20 Jan 2025 12:03 PM
No, typically not. Sky and other ISP personnel aren't trained or equipped for duct work: that's an Openreach thing.
Message posted on 20 Jan 2025 02:48 PM
Thanks all.
My query is that open reach haven't been out at all yet; and I'm due to switch in 7 days. I didn't know if this was normal, or if open reach should have completed the external work yet.
Message posted on 21 Jan 2025 04:59 PM
We've got similar - expecting connection on Thursday 23rd - had a notification a few weeks ago that the Sky engineer visit (2nd of the 2 visits) was cancelled and it said Openreach will do everything to connect us up... Like you I was also expecting a 2 stage installation process with an initial visit then a follow on - will have to wait and see what happens on Thursday,... I remember last time the whole Customer -> Sky -> Openreach comms being a total nightmare (so going into this install with eyes wide open), hoping to avoid that pain again.
