Discussion topic: Sky Fibre router reboot anytime, anyday randomly and at the most inconvenient of times usually
Message posted on 16 Feb 2026 03:08 PM
My Sky fibre router
Message posted on 16 Feb 2026 03:19 PM - last edited: 16 Feb 2026 03:19 PM
Re: Sky Fibre router reboot anytime, anyday randomly and at the most inconvenient of times usually
@MattLinehan What extenders are you using, make and model? If third party models RE or AP mode!
Message posted on 16 Feb 2026 04:26 PM
Errr, TP Link in Extender mode - not sure why that's relevant. It has the fault with our without extenders. Same fault, runs out of memory, reboots the router.
Message posted on 16 Feb 2026 04:31 PM
In Addition to this I just got off a call with a Sky "engineer" who asked me to push the reset button for 15-20 seconds.
I said "sounds like a factory reset.... I don't want to do a factory reset without backing up the settings. This is a router that replaced a previous router and I gave it the SSID of the old router to save having to reconfigure everything, I don't want to factory reset, this won't factory reset will it?"
"No... just needs 15-20 seconds hold down the reset button at back"
Do it for 15 - does a factory reset.
When I told her it DID do a factory reset she says "you must have held it down for 30 seconds". Should have known better really.
Message posted on 16 Feb 2026 04:39 PM
@MattLinehan No problems will leave you to get on with it!👍
Message posted on 16 Feb 2026 04:56 PM
Thanks, but if you're after tips for Extenders, they are Model RE315, Hardware RE315 1.0 and integrate with the Tether app - which is pretty neat. They work fine as long as the carrier wifi connection isn't ripped out from under them with a sudden and unexpected reboot 🙂
Message posted on 03 Apr 2026 04:27 PM
I've been getting the same issue, rebooted the fibre box coming into the house, and now the router seems to have stabilised. Weirdly, our router would drop at about 7 pm on various days.
Message posted on 24 Apr 2026 10:50 AM
Yep, tried that quite early on but doesn't make any difference. Still getting
skyhub.ihr skytelemetry Device Doctor reboot. Shared memory critically low, total: 503kb, used: 443kb, free: 60kb, threshold: 60kb
Then reboot.
Then walk round the house turning things off and on again.
Would leave Sky but i'm tied into a contract but will go once that's up. Appalling service from the entire organisation.
