Discussion topic: Sky Broadband
This message was authored by: Anzhelika
Sky Broadband
Hello. I need to activate the device, but I don't understand where to plug the black cable with the two yellow tips? One tip goes into the device and the other yellow?
Re: Sky Broadband
@Anzhelika
That's an ethernet cable: it's intended to go between a Sky Broadband Hub or Max Huband and an ONT (Optical Network Terminal or 'fibre modem')
If there isn't an ONT at your address then it may either be missing or yet to be installed.
Re: Sky Broadband
@Anzhelika Below is the Electronic version off the Home Help setup guide.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Avatar for Anzhelika
Re: Sky Broadband
Do I need to order this ONT and from where, as I don't have such a device.. Thank you
Re: Sky Broadband
@Anzhelika Have you ever had, new to the property, give us something to work with help wise!
Re: Sky Broadband
@Anzhelika
Installation of the ONT is part of the process and can happen up to the activation date.
The exception is where there's previously been an ONT at the address which is now missing: that needs to be reported to Sky.
If it's in the UK, putting the address into the BT Wholesale Availability Checker should indicate if an ONT is supposed to be present.
