5
This discussion topic has been answered Discussion topic: Sky Broadband super slow on my new HP Laptop, other devices fine
This message was authored by: Muisface
I recently got a new HP work Laptop and from the word go I've had internet issues. I connect wirelessly to the router and the internet speeds I get are between 5 and 30 mbps, when I get between 180 and 300 mbps on other devices, including other laptops.
I am having issues with work video calls so wondering if there is an issue is more likely with my Broadband or the actual laptop, so I can start looking at fixes. This situation cannot continue.
Thanks all
Avatar for Muisface
This message was authored by: Muisface Answer
Re: Sky Broadband super slow on my new HP Laptop, other devices fine
Yep, literally side by side.
Thanks for that, Ill get them to look into it.
@Muisface
If other devices are fine & get good speeds then its hard not to blame the laptop.
Whats the model number of it?
I am NOT a Sky Employee
Avatar for Muisface
Its an HP Elitebook 650 G9
@Muisface
I would get your work to check drivers etc because that laptop supports WiFi6e so should be as stable as any other device you have.
Is it a similar distance away compared to other devices?
Avatar for Muisface
@Muisface
Is the laptop configured to automatically connect to a business VPN?  That can drastically affect speed.
