Discussion topic: Sky Broadband down!
This message was authored by: Lauren_93
Sky Broadband down!
Restarted the router, done all the IT essentials, it is down!!! Please fix urgently!! Lifeline equipment in household
Re: Sky Broadband down!
@Lauren_93   You're not speaking to Sky Customer service, nothing will be done as a result of your post.
First thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
Please be aware that outages after midnight are usually down to maintenance, please see this pinned post https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
Avatar for Lauren_93
Level 0 icon
It says there isn't when there clearly is. My partner is an IT technician so we have done all the essentials our end
@Lauren_93  Did you read the bit about outages after midnight?
These are outside of Sky's or any other ISP using the Openreach network control.
This message was authored by: GuyGDorset
Yeah mine is down also in Dorset. The Sky checks say connected but not. Tried the usual re-boots and tests.
This message was authored by: Claire771
Mine to, also done all checks, im in South wales
@GuyGDorset @Claire771
As stated above by @GD1 any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
No ISP can possibly guarantee uninterrupted internet access, nor do they ever claim to do so.  Critical equipment should have alternative connection methods.
