This discussion topic is read only Discussion topic: Sky Broadband Speed to Hub
This message was authored by: Baz.
Over the past few months My broadband speed has been getting less and less I've just run a Sky speed Test and I'm now getting 59mbps to the hub my guaranteed Minimum download speed is 64mbps with a normally available download speed of 69 to 73mbps I use to get 71 or 72 mbps  we have had a open reach tech out who run some checks and he said that 62 is the most we would get,  we used to have two phones lines coming in to the house but stopped using the 2nd line years ago so this is why the plug set up looks different the phone socket does not have a broadband connection in so does not need a microfilter.
I'm just wondering if anybody can think of a reason why the speed is slowly dropping or if it is worth getting openreach back out again.
My Set up
Sky Q 2tb 32B0
Samsung QE55QN85A
Sky Q Mini x 3 via wifi using Grain Connect FTP
Samsung S23 Ultra
Samsung HW-Q800A/XU 3.1.2 Wireless Sound Bar
HP Pavilion 14-dv1629sa 8gb ram Laptop Windows 11 Home
Joined Sky Community 8th November 2010
Click the following link if you want to Send your Thanks to Sky
Locked
Re: Sky Broadband Speed to Hub
@Baz.
Have you posted your routers stats it will take a while to moderate.  Can you copy and paste them
https://community.sky.com/t5/Broadband/How-to-find-your-Sky-Broadband-router-stats/m-p/2855717#M1014...
Out of interest is the sr203 connected to a large openreach ont modem plugged into an ethernet port or a standard openreach mastersocket?
@Baz.
I can't pretend to undestand the setup vis a vis the mass off wiring . We need to see the router stats. As well as post the results from my sky app->broadband->run tests->more about your connection. At the end of the day if you are below the minmum speed guarantee you'll end up contacting sky anyway
Avatar for Baz.
Level 15 icon
Sorry @cookiemonsteruk  i thought I had posted that as well ,    there is no master socket and the Sr203 is plugged into the left hand socket which only has the broadband connection running to it and is pre microfilter on it (so the openreach tech says )
My Set up
Sky Q 2tb 32B0
Samsung QE55QN85A
Samsung S23 Ultra
@Baz.
I'm wondering if the aforementioned pre micro filter a gpon ont.  Can you remember if your speed was showing at the bottom of the post? Can you copy and paste it instead and finally perform run tests from my sky and post . Thanks
Avatar for Baz.
Level 15 icon
Broadband LinkDownstreamUpstream
Connection Speed60882 kbps16009 kbps
Line AttenuationD1(8.3 dB) , D2(19.5 dB) , D3(30.4 dB)U0(0.1 dB) , U1(14.4 dB) , U2(23.4 dB)
Noise Margin6.3 dB6.1 dB
My Set up
Sky Q 2tb 32B0
Samsung QE55QN85A
Samsung S23 Ultra
@Baz.
Bang goes the gpon theory. .pending confirmation of mgals call sky and book an engineer to fix and tidy up the spaghetti and find out what the pre microfilter thing is all about 😁
@mae-3
Any ideas.  Set up looks iffy to me
Avatar for Baz.
Level 15 icon
Some of the wires in the picture have nothing to do with the broadband it's been like that for a good few years and I mean a good few years .  I've only started to have the issue in the last 4 or 5 months  like I said open reach have already been out and found no issues and they say that's the best my line will support.
My Set up
Sky Q 2tb 32B0
Samsung QE55QN85A
Samsung S23 Ultra
@Baz.
Line attenuation suggests closer to 80Mbps in conjunction with 64Mbps guarantee suggest different . Can you describe this pre microfilter or post a photo
@Baz.
Or is that what they described as pre microfilter.?
@Baz.
Sorry for all these seperate questions , one eye on the olympics one on the mobile
. Where does the grey cable going into the box lead back to?
Avatar for Baz.
Level 15 icon
Pre microfilter  so unable to take picture of microfilter
My Set up
Sky Q 2tb 32B0
Samsung QE55QN85A
Samsung S23 Ultra
@Baz.
I tagged another forum member earlier on. i have reached the limit of my lack of expertise and lapse into inane babble mode.  Hope you get it sorted 👍
This message was authored by: mae-3
@Baz. & @cookiemonsteruk
The router stats and that wiring look a little suspect internally for maximum speed obtainable. The reason the BT Openreach engineer is stating that's the maximum you'll get is the noise margin is around the 6dB but the attenuation would indicate the line capable of more but noise not so.
20Mbps below the maximum on a relatively short line, estimate about 230-240 metres to the cabinet as the cable runs. And you've got a rather low upstream speed additionally.
I state you have a line fault at that distance to the cabinet but will BT Openreach send another engineer?
[add] Also, looking at the router stats, upstream mainly, I say the fault is about 7-8 metres from that telephone socket as the cable runs or its bridge tap at that point before running to that telephone socket. The reason it's not likely to show up until recently is the cabinet is likely almost or nearly full now and that wiring is more susceptible to cross-talk because of the educated guess there is a bridge tap local in or near the premises?
Zen internet on FTTP (900Mbps down, 100Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS. Dr Mae-03 PhD.
Locked
