12 Apr 2022 12:41 PM
Hi there, I am looking to get a mesh WiFi network set up in my home to eradicate dead spots and get coverage in my new garden room, and really like the look of the Google mesh set up, considering I already have a number of Google smart home devices.
I read last year that Sky broadband routers really don't get along with Google Nest, but it was my understanding that this was because the Sky Q setup was a mesh system and therefore they constantly competed with each other. Now I no longer have Sky Q and have moved to Sky Glass, will this no longer be the case?
Any advice will be greatly appreciated before I spend 300 quid on a setup I can't use...! 😅
TIA
12 Apr 2022 01:18 PM
Posted by a Superuser, not a Sky employee. Find out moreYou should be fine but keep in mind that Google Mesh is unable to authenticate via Sky's systems on its own so you'll still need the Sky hub in place which means you'll either have double NAT or have to put the Google Mesh system into AP mode
12 Apr 2022 01:22 PM
Thanks for your answer mate. Is that relatively simple to do? Does it mean just plug one of the Nest units straight into the Sky modem with an ethernet cable, then the other units wherever I need them?
Cheers and apologies - I'm a proper layman!
12 Apr 2022 01:23 PM
Posted by a Superuser, not a Sky employee. Find out morePretty much yeah. The Google setup guide will tell you exactly how to do it but its pretty much a case of plugging it into the Sky hub and going from there
12 Apr 2022 01:24 PM
Awesome, thank you!
09 Nov 2022 03:33 PM
Hi, Just reading this discussion - did this work okay for you as I am looking at doing the same.
Cheers
Phil
17 Nov 2022 12:19 PM
@GavYCK @Pct95 I'm in exactly the same position - if you can share your experiences, that would be great.
I will have Sky Broadband Ultrafast Plus installed next week. I am happy to keep the Sky modem. But I want to run a mesh wifi due to house size/wall thickness - ideally a Google Nest Wifi Pro (just as a router connected to the Sky Broadband modem via LAN cable). There is a lot of confusing information on the internet and different forums about what will and will not work - seems to be Sky Q related mostly.
Note: I do not have Sky Q / multiroom (just an old Sky+HD). I have an existing Tenda MW3 / MW5 mesh wifi I want to upgrade at the same time as getting Sky Ultrasfast Plus as it is very tempremental.
