11
This discussion topic has been answered Discussion topic: Sky Booster stopped working
This message was authored by: AntOnSky
We have both TV and Broadband provided by Sky.
The Sky Booster was working fine for ages, but as of this week it has stopped working properly.
There is only 1 light on: the green Power light.
When I press and hold the WPS button for 4 seconds, it does NOT flash amber (or light up in any colour!).
Neither the Wifi light or the Connected light are lit anymore.
This message was authored by: JimM1 Answer
Re: Sky Booster stopped working
@AntOnSky Looks like you managed to keep the Engineer on the straight and narrow path, new one working fine, then the old one had given up the ghost, it does happen and nothing last's for ever!🤣👍
@AntOnSky See if the reset does anything to get it going, if not you may just need to call sky for a replacement unit, there are two the SE210 with an Ethernet connection and a SE210a without the Ethernet so be sure to ask and get what you need! Link below will walk you through the reset and then to re connect the unit back to the Sky Hub!
https://www.sky.com/help/articles/sky-wifi-booster-what-do-you-need-help-with
@AntOnSky try the booster in the same room as the hub if it doesnt link there it it is probably faulty and you should ask Sky to replace the booster.
This message was authored by: arcadeavenger
Posted by a Sky employee
Hi @AntOnSky, I’ve escalated your post to our Community Messaging team who will invite you to a private chat shortly and help you with this.
Avatar for AntOnSky
I should have put that in my original post: yes, I have already reset it twice!
Avatar for AntOnSky
Thanks. I have already tried it in the same room. And even connected via Ethernet cable.
Neither worked.
But seems odd that it would just suddenly stop working.
@AntOnSky Your post has been escalated for you now, so sky CS ia the best way for you to go chatting with them!
If you have reset it as per the link, and it does not go to the two outside lights, more than likely it's gone faulty, items dont last for ever, but will say my 2019 SE210 is still working fine!
  1. Hold RESET on the back of your booster  for 10 seconds, or until the power light flashes green.
  2. When the power light turns solid green, it's reset.
Avatar for AntOnSky
The Sky Expert suggested I change my Gateway address. So I did. But now theirSky chat error.jpg messages won't display, so I can't talk to him anymore !!!!
Hi @AntOnSky I have sent you another invite to chat to continue.
Avatar for AntOnSky
A Sky TV team came today and (reluctantly) replaced the Booster.
One of them said the problem was that the router had both 2GHz and 5GHz. I said surely that's expected as it's a dual-band router.
He then said he's not technical 🙂
But finally he agreed to replace the Booster, and so far it's working.
Thanks everyone for your input.
This message was authored by: Brian75
Do you have a phone number to ring sky, getting no sense out of virtual assistant
