Discussion topic: Since skyfibre no broadband shield
Message posted on 03 Jan 2026 03:47 PM
Message posted on 03 Jan 2026 04:06 PM - last edited: 03 Jan 2026 04:11 PM
Re: Since skyfibre no broadband shield
@-NigelW- You can have sky adjust it to whatever setting you need, do you require to be constantly adjusting it yourself?
Have sky check the account side, once all setup you should be able to check and do everything, also try from another device to see if you can get to it and adjust!
Had a quick check against mine on the account looks to be working although i never saved but adjustments looked to be changing, do have mine switched off as not in use and also on a FF500 connection!
