Discussion topic: Signal strength
This message was authored by: Seamus_1959
Message posted on 05 Dec 2024 08:42 PM
Signal strength
Over the last year my signal strength has got really weak I got one of those extenders which did work. I am try to get the signal to my shed for training apps. I am going to try another provider nothing to loose
Find out more
Message posted on 06 Dec 2024 08:31 AM
Re: Signal strength
@Seamus_1959 you would be best advised to run an external grade ethernet cable from the hub to your shed and use that to connect to a Wifinaccess point or directllyvto your device as wifi signals from any source in your home lose strength when passing through an external wall. Otherwise place whatever extender you want to try in a window facing the shed.
