Discussion topic: Signal ptoblem
This message was authored by: Parisa
Signal ptoblem
The lights are on green then one goes red losing signal been happening for 3 days and I'm not happy
Re: Signal ptoblem
This is a customer forum, have you called Sky in the last 3 days to report it?
If you use the app or website  you can force a check and if there is a problem it'll log it and perhaps set up an engineer visit to sort it.
Re: Signal ptoblem
@Parisa you can log into the My Sky app when the line is up and click to run the test - ignore the result of the last regular test - if it finds a fault it can book an engineer otherwise call Sky.
