Discussion topic: Signal keeps dropping, then says limited connection
This message was authored by: Allaw
Over the last 2/3 days the signal keeps dropping and then says limited connection. It's 830 Sunday morning and this has happened 5 times already this morning.
Re: Signal keeps dropping, then says limited connection
@Allaw look at what jhappens to the lights on the hub when you lose connection and use this guide https://www.sky.com/help/articles/hub-lights-explained-start
If the hub is dropping the connection to the  exchange  repeatedly and it isnt a lose cable give Sky a call as the online service checker doesnt pick up short disconnections.
