Discussion topic: Signal keeps dropping out
This message was authored by: JulieD75
Signal constantly drops out during paid for streaming services. At the moment my Sky is saying it's unable to connect to my router yet other things around the house connect perfectly fine. Happening too often. My guess is it's an obsolete router which we are still using.
Re: Signal keeps dropping out
@JulieD75 Sky are replacing the hub's on the second row in the picture on this page https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have if you have one of those then call Sky to get it swapped out.
If you have one of the models on the top row they are all current. Streaming video requires a strong wifi connection free from interference. Tge most likely cause is the TV or streaming box is in an area with insufficent signal. There is a simple way to check thecspeed the unit is connecting at which is run the Network Test in the Get Help menu of the Netflix app.Sounds like you msy need to get an extender or similar.
