Discussion topic: bt Home hub won't connect to sky
Message posted on 03 Sep 2025 09:15 PM
I got a nerw sky hub yesterday, plugged it in and now my BT Home hub won't work so can't get any connection across the house.
The frustrttaing bit is it will work for a few minutes after resetting but not long enough to do anything - please help with advice as I HAVE TRIED EVERYTHING
Message posted on 03 Sep 2025 09:35 PM
Re: bt Home hub won't connect to sky
@briggo1 If your using a Sky hub and your broadband is provided by Sky why are you using the BT hub?
Message posted on 04 Sep 2025 07:08 AM
@briggo1 most BT WiFi kit wont work with Sky's hubs and vice versa. Sounds like you msy need to add Sky's WiFi Max which can give you matched wifi extenders see https://www.sky.com/help/articles/sky-wifi-max
Alternatively buy your own wifi system and use that instead.
