Discussion topic: Signal issues .
This message was authored by Nida1 This message was authored by: Nida1
Signal issues .
Very poor wifi signals it is an ongoing issue. Need this resolved.
Re: Signal issues .
@Nida1  Do you have bad or weak Wi-Fi thoughout the property?
Nida1
Re: Signal issues .
Yes. I had this problem in my last appartment and now again in this place.
Re: Signal issues .
@Nida1  Do you have broadband boost or broadband max as part of your broadband subscription?
Nida1
Re: Signal issues .
I don't think so. We have super-fast Internet.
Re: Signal issues .
@Nida1  If you give Sky a call and explain to them about that lack of Wi-Fi in the property they will talk through your options. If you have a landline just dial 150 and listen to the options and ignore if they send you a text and wait to speak to an advisor.
If you are calling via mobile phone you can find the number at the bottom of the link below under "Need more help ".
https://www.sky.com/help/home
