Discussion topic: Signal drops out in garden
This message was authored by: Iamdeaks
Signal keeps dropping out from garden- is it possible to have an extender?
Avatar for Iamdeaks
Re: Signal drops out in garden
Ps I believe I can have upto 3 as I'm on sky WiFi max- is that correct?
@Iamdeaks  You will need to call SKy as the community can send anything.
These are the current methods for contacting Sky. (Depending on your reason for making contact some methods will be more appropriate than others) …
🔶📞 Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline.
All calls will start automated which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and saying nothing when asked the reason for the call sometimes helps being put in the queue for an agent.
Note: if your services are restricted due to a missed payment phone contact is unlikely to work.
🔶online help via this link
https://www.sky.com/help
🔶 Sky Assistant should also be available via
🔶Social Media You can also get in touch via the messaging services on: Facebook, Instagram, or X (links at the bottom of the forum page).
Note If you’re in the ROI make sure the flag in the bottom right of the link is showing the correct flag and change if required.
@Iamdeaks
The Wifi Max guarantee does not cover gardens:
The WiFi Max Guarantee doesn't cover unconverted lofts, gardens or external rooms, buildings or structures, like sheds or garden offices.
