Discussion topic: Broadband signal
Message posted on 10 Aug 2026 02:03 PM
Broadband signal
So our broadband has generally been working ok in most of the house apart from 1 room where it cuts off every now and again and the speed is slower (videos lagging). We have a sky puck in that room which also disconnects occasionally. Do sky provide boosters?
Message posted on 10 Aug 2026 04:57 PM
Re: Broadband signal
A poor signal in certain rooms is something that can cause this so try going through this to see if it helps:
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
Alternatives are homeplugs or your own mesh network.
