Discussion topic: Signal OUT IN MOORGATE
Message posted on 26 Jan 2025 12:53 PM
I'm really not happy I'm paying a lot got Sky and NOT getting a SIGNAL I have recently got upgraded with a SUPERSAST line, but it is USELESS
Message posted on 26 Jan 2025 01:00 PM
Re: Signal OUT IN MOORGATE
@Trisha9H
The lines may be busier due to the damage and disruption caused by Storm Éowyn which will also impact an Openreach visit.
