Discussion topic: Setup sky hub problem
This message was authored by: Ali8117
Hello, I recieved my sky hub router and I setup mu sky hup as the small booklet which comes with it. But when I connect my router the red light get solid while my activation's day is today and I received the message that we activated your hub.
I just enclosed photos as well.
Thank you for reading my message and your help.
Re: Setup sky hub problem
@Ali8117
If that white ethernet cable is going to an ONT then it should be in ethernet port #4 (marked WAN) rather than port #1 where it is now.
