Discussion topic: Setting up a new Giga Fast hub
Message posted on 22 Aug 2026 02:05 PM
I have an existing BT broadband hub, but thinking of switching to the Sky Giga Fast hub. I have told that setting up the Sky hub is simply matter of transferring the all the leads at the back of my BT hub to the Sky hub. Is this correct? The Sky customers person I spoke to didn't seem to know the answer to this question.
Message posted on 22 Aug 2026 05:24 PM
Re: Setting up a new Giga Fast hub
@Reggles1 broadly you are correct however you will have to connect your WiFi devices as the SSID and password will be different (or chsngecthe Sky hub's details to match your old BT hub). See https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Message posted on 22 Aug 2026 06:33 PM
Chrisee,
Many thanks for your reply. It was very helpful.
