Discussion topic: Broadband not working
Message posted on 22 Aug 2026 07:03 PM
My broadband not working properly all day long is in and off keep flashing in amber colour second boton from the left and the last boton from right. Flashing all the time comes and go not stable at all
Message posted on 22 Aug 2026 07:08 PM
Re: Broadband not working
@Abdelkrim121
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
(this won’t necessarily identify a fault just affecting your address).
🔸Various hub lights; This link provides information about the coloured lights you may see on the various hubs
🔸Red light on ONT?; See this link ~
🔸Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
