Discussion topic: Safety is on
This message was authored by Kledisa+Habilaj This message was authored by: Kledisa+Habilaj
Safety is on
Hi I have a problem with Google the safety is on I can't take it off I need it off
This message was authored by PandJ2020 This message was authored by: PandJ2020
Re: Safety is on
  1. Open your preferred web browser.
  2. Navigate to Menu > Settings.
  3. Check that cookies are enabled. ...
  4. In your browser, navigate to Google.com.
  5. Scroll to the bottom of the web page.
  6. Tap Settings.
  7. Under SafeSearch Filters, select the appropriate filter.
  8. Scroll to the bottom and tap Save.
I am just another Sky customer and my views are my own
Kledisa+Habilaj
Re: Safety is on
"You can't turn SafeSearch off right now because someone else, such as a parent or administrator, controls settings on the network, browser or device that you're using.""
Mir shows me that I can't take it off didn't allow me
Re: Safety is on
@Kledisa+Habilaj
You need to turn off Sky Shield first
I am NOT a Sky Employee
This message was authored by Devils+Advocado This message was authored by: Devils+Advocado
Re: Safety is on
If turning off Broadband Shield doesn't work - try accessing the router and in the Security tab change "Block Keywords" to "Never"
This message was authored by mae-3 This message was authored by: mae-3
Re: Safety is on
You need to be the account holder to turn off the safe search on Sky broadband shield, eg: sky shield should either be set to eighteen or turned off completely.
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
This message was authored by Levershouse67 This message was authored by: Levershouse67
Re: Safety is on
How do I turn it off
