Discussion topic: SSID keeps changing on router
This message was authored by berteboy This message was authored by: berteboy
Hi all,
Has anyone had an issue where their SSID changes on the router so none of the WiFi devices can connect?
Luckily, I have an access point connected to the router via enternet otherwise I'd be without access.
Thanks,
Lee.
Re: SSID keeps changing on router
@berteboy
Changes to what?
The only likely situation is where a customised SSID is returning to the default factory one because the router is resetting.
