20
Discussion topic: SR203 Router Problem
This message was authored by loverboi This message was authored by: loverboi
Re: SR203 Router Problem
@Highlinder @dude1547854 but if you have sky mobile yopu could call them on your mobile on 150😁😁
@loverboiYes you could.
This message was authored by Podestas This message was authored by: Podestas
Turning it off for 15 minutes soled my problem with it,
This message was authored by mae-3 This message was authored by: mae-3
Diverted calls I thought usually cost per diverted connection fees and minutes?
Zen internet on G.fast (250Mbps down, 50Mbps up). SAT> IP (Apple 4K 2nd gen TV to LG C1 OLED UHD TV/Dolby Atmos Denon AVR, DacMagic Plus for Hi-Res audio), hosting own blog/forum (cluster), OPNsense & Zenarmor L4/L7 NGFW & DPI IDS/IPS, Asus ET12 Pro Tri-Band wifi, Linux, Gamer: Xbox Series X/i7 laptop, round-robin DNS over HTTPS, non-proprietary VoIP HD AMR-WB (G.722.2) and more... Beta tester Apple iOS/watchOS/tvOS/iPadOS/macOS.
Think you are right @mae-3  according to this page https://www.sky.com/help/articles/sky-talk-call-features
diversion to a mobile is chageable per minute to the Sky customer and the fee is £2.50 a month unless I am missing something.
Best solution if it is possible would be to port the landline number to a VOIP service
This message was authored by AFLAC7 This message was authored by: AFLAC7
I had an identical experience yesterday, downstairs power tripped and then router intermitently cycles the power light through red and green.
I have left powered off for hours it makes no difference, nor does reset.
I have requested a replacement from Sky.
In the meantime is there anything that can be done with the original router, or is it goosed ?
