6
This discussion topic has been answered Discussion topic: . SONOS/SKY BROADBAND not compatible
This message was authored by: Bobbysox
Recently got Sky broadband. My SONOS system no longer works. SONOS say this is a known problem and can be solved by editing the SS ids which requires unticling the 'synchronise' 2.4GHz and 5GHz settings. I need help from SKY to do this
Avatar for Bobbysox
This message was authored by: Bobbysox Answer
Re: . SONOS/SKY BROADBAND not compatible
All ok
ive sorted it. SONOS now working
On a Sky Broadband Hub that's typically a DIY job: unfortunately it's not achievable on the Max Hub.
Avatar for Bobbysox
Many thanks for the response. Could sky technical team fix this for me
Avatar for Bobbysox
All ok
This message was authored by: Me134
@Bobbysox wrote:
All ok
How exactly did you sort it?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Avatar for Bobbysox
I got someone to edit the SD IDs and essentially create two ways to log on to the broadband. Just need to choose the right one, which allowed me to put all the SONOS components on to a new group system .
I have the Beam 2 and have had it connected to the Sky wifi, the TP-link wifi and of course ethernet and it's never missed a beat. I'd guess yours is a different model or surround sound setup?
Not a Sky employee
