Discussion topic: SKY router isn’t broadcasting SSID, but connected WiFi extender is working
This message was authored by: AndyP1999
Message posted on 24 Sep 2024 03:30 PM
my SKY router has stopped broadcasting its SSID so I can't connect to it - but a WiFi extender (connected via Ethernet) is working fine... any ideas how to get the SKY SSID back? Thanks
Find out more
Message posted on 24 Sep 2024 05:41 PM
Re: SKY router isn’t broadcasting SSID, but connected WiFi extender is working
@AndyP1999 Can you do a factory reset on the max broadband router by pressing the WPS button waiting for it to change colour.
Message posted on 24 Sep 2024 06:00 PM
It worked - thanks!
