Discussion topic: SKY TV
Message posted on 09 Jun 2026 09:57 PM
SKY TV
Message posted on 10 Jun 2026 05:52 AM
Re: SKY TV
@AidanBourke if you have Sky Stream or Sky Glass it sounds like thee WiFi signal is suffereing from interference from your neighbours' WiFi networks. Streaming video requires a staedy signal which interferenceccan disrupt. Suggest you try rebooting your Sky hub which causes it to find the least congested WiFi channel to use. However the best permanent solution is by impriving the WiFi signal in your home or better using Ethernet cables if that is pactiical.
Message posted on 10 Jun 2026 08:21 AM
Re: SKY TV
I been on the phone 3 times in the last 8 days, I shouldn't have to reset my box 3 or 4 times in a evening, the quality of the service is not meet the standards I expect.
