Discussion topic: SKY OUTAGE LIVERPOOL AREA
This message was authored by: Andreaxoxox
Hi
Has anyone in the Liverpool are that is having the Braodband Outage problem actually had any contact from Sky, I have spoken to them and they said the usual 'we are working to get broadband back on' its been 10 days no broadband in my area, working from home, Sky is just the biggest joke!!!
Re: SKY OUTAGE LIVERPOOL AREA
Typically area outages cause this forum to explode, and I'm not aware of any similar posts in the past couple of weeks.  Are you sure it's not a very local or individual address issue?
Avatar for Andreaxoxox
Nope, definitely an outage in the area as other people in the road are off too, ans Sky have said too, so not sure as to why people are not aware
@Andreaxoxox  If it's road outage you need to be aware they all won't be with Sky but other providers.  As yours is the only post it would suggest a small area outage rather than a wider area.
@Andreaxoxox
There may be delays if Openreach have to dig up the pavement or road as part of their investigation/fix as they have to gain permission from the local council. Also be aware working from home is irrelevant.
If you're not already aware the below link explains the Ofcom agreed auto compensation scheme which Sky operates for when there is a TOTAL loss of Sky Broadband or Sky Talk.
https://www.sky.com/help/articles/auto-compensation
If you have a total loss of service and it isn’t fixed after two full WORKING days from when you first report the fault to Sky, you will become eligible for it. It’s applied 30 days after the fault has been repaired and will come in the form of a credit appearing on your Sky account.
