Discussion topic: Routers with Gigafast Fttp
This message was authored by: ShaunC85
have an engineer installing Gigafast on the 7th October. Do I stick with the new router they supply? I have an Asus ax3000 that im sure has a wan port. I've also read that Sky do another router at £3 a month for gigafast?
any advice @TimmyBGood
Re: Routers with Gigafast Fttp
@ShaunC85
Have you or do you sky q with more than 1 mini box .
The standard hub for fttp is the sky max hub although the asus should work well directly connecte the ont
You'd receive the Max Hub by default with a new FTTP order: the additional monthly cost is for the optional WiFi Max service.
Avatar for ShaunC85
Level 3 icon
I have sky Q but no mini box anymore. Is the sky max hub sufficient or shall I use my own? I'm a gamer in a busy household, by busy I mean mrs and 3 children
@ShaunC85
For someone who has a busy household & games I would always recommend going towards the route of a 3rd party router.
I am NOT a Sky Employee
@ShaunC85
I upgraded to full fibre last week and it appears i still can't get sky sky max due to sky q main showing on my account even though i am stream now. So would recommend the asus for its adaptive qos and prioritisation.  The sky max seems to have a packet prioritisation but appears to be cloud based so not much feedback to enable us to give advice
@ShaunC85
One point to consider is that without the Max Hub as the primary router you cannot have 'landline' telephone calls.
Avatar for ShaunC85
Level 3 icon
Right guys Gigafast all installed as of yesterday. Is it straight forward plug the ASUS ax3000 into the new Onit and away we go or do I need to mess with stuff? Also shall I try it today or give it a few days?
@ShaunC85 if you doasearch of the forum you will find pictures of the srttings you nedd to change on your Asus router.
