Discussion topic: Router wont reset
Message posted on 29 Sep 2024 10:12 PM
Router wont reset
Router won't reset even when the test said everything is OK
Message posted on 30 Sep 2024 07:07 AM
Re: Router wont reset
@DRAGON2 normal reason why resets fail is not waiting long enough. With the black hubs hold the reset pin in until the power LED fkashes which can gake 20 seconds. On the white hubs you need to hold the WPS button in until the msin LED flashes green rapidly which takes up to 30 seconds.
You should only need to reset the hub rarely if the line is down (https://www.sky.com/help/articles/hub-lights-explained-start) then a reset wont restore it ifva standard restart didnt. You need to report the line fault to Sky - the online tests reports the last routine test not the current position.
