Discussion topic: Router setting up 2.4 kh and 5 kh
This message was authored by: Anthony+Crowder
sky gave me a new router , sky hub but ring doorbell isnt working as it cant work on 5 kh
Re: Router setting up 2.4 kh and 5 kh
@Anthony+Crowder
What colour of hub do you have
@Anthony+Crowder
Read youlink below on how to seperate the wifi bands for the black hubs or temporarily disable 5ghz until you have connected the ring device for the white sky max hub
https://helpforum.sky.com/t5/Broadband-Talk/How-to-separate-WiFi-bands/ba-p/3530610
P
Avatar for Anthony+Crowder
white
@Anthony+Crowder
You'll need to disable 5ghz and then turn wifi of and on on your mobile device so the ring app only connects to 2.4ghz .  The camera will then connect to that wifi band
This message was authored by: Sue_Doe
That's "GHz"!
