Discussion topic: Router over heating
Message posted on 04 Jun 2025 07:15 PM
Router over heating
My router keeps over heating it is on it own on a table in the kitchen the casing has also started to yellow from the heat
Message posted on 04 Jun 2025 07:52 PM
Re: Router over heating
@Jess170 What hub do you have that is getting so hot to cause that problem! Link below if you are not sure will show types.
https://www.sky.com/help/articles/set-up-hub-which-sky-hub-do-you-have
Message posted on 04 Jun 2025 09:10 PM
It's a sky max hub
Message posted on 04 Jun 2025 09:16 PM - last edited: 04 Jun 2025 09:18 PM
@Jess170 Does it feel really warm to the touch? And if you know are you connected full fibre or via a OR Master Phone socket?
Message posted on 05 Jun 2025 08:33 AM
Yes the casing gets very hot we are connected to phone socket
Message posted on 05 Jun 2025 11:08 AM
@Jess170 If you are finding that it is getting that hot, you need to call sky let them know and have them organise a replacement for you.
Dial 150 if you have a landline, else you will the number in the link below, just click on th need more help, scroll down and you will see it.
