Discussion topic: Router not recognising HP printer
Message posted on 26 Feb 2024 12:55 PM
Printer has always worked fine, but since we have changed to Sky Glass it won't connect. Have tried pressing WPS button on printer and router, it gets so far then message comes up; Error....progress stopped. What can I do
Message posted on 26 Feb 2024 02:14 PM - last edited: 26 Feb 2024 02:15 PM
Re: Router not recognising HP printer
Glass is a Sky-branded television set.
Did you also change your broadband to Sky at the same time as ordering the Glass television?
Message posted on 27 Feb 2024 01:01 PM
Or perhaps you had Sky Q before and the WiFi signal strength is no longer being booster by Sky Q boxes so your printer is out of range?
