This discussion topic has been answered Discussion topic: Router keeps dropping out regularly
Message posted on 24 Jul 2024 04:48 PM
Sky router has to be rebooted regularly since it was installed some 6 months ago
Message posted on 25 Jul 2024 09:52 PM
@goodlookingone Does data flow stop and do any of the lights on the router change colour or go out all together/
Message posted on 26 Jul 2024 08:37 AM
Re: Router keeps dropping out regularly
Yes one light turns red
Message posted on 26 Jul 2024 11:07 AM
@goodlookingone Which light turns red? Is it the internet light?
Message posted on 26 Jul 2024 01:21 PM
Yes internet light only
Message posted on 26 Jul 2024 02:30 PM
@goodlookingone Is this happening daily for you or is only once in a blue moon? Sky will be pro-active if it is happening more than 5 times a day depending on the connection type.
Message posted on 26 Jul 2024 02:50 PM
It happens once or twice every two weeks
Message posted on 26 Jul 2024 03:10 PM
@goodlookingone Have you noticed if it is around the same time of day or even the same day each time this happens?
Message posted on 26 Jul 2024 03:42 PM
No- can be anytime of day
Message posted on 26 Jul 2024 04:12 PM
@goodlookingone Are you always at home when this happens as it would be more ideal that is not rebooted right away to see if this can be picked up as a fault. Does the lights on the ONT change at all when this happens or is it only the router that the lights change on to indicate that there has been a drop in the connection?
