Discussion topic: Router keeps dropping at same time everyday
Message posted on 24 Jun 2026 11:35 AM
Message posted on 24 Jun 2026 11:40 AM
Re: Router keeps dropping at same time everyday
@Lordbasil wrote:
As I work from home on a 24/7 emergency phone line I can't work whilst the reboot completes.
Realistically no fixed line ISP can guarantee uninterrupted service: the topology of the cabled network makes that impossible.
You might want to consider using a provider which has automated failover to cellular data (at an additional monthly cost)
Message posted on 24 Jun 2026 01:15 PM
This fault only manifested itself onTuesday 27th May @ 16.56 hrs - it continued to drop daily at the same time until Wednesday 3rd June.
4th of June it was ok and on the 5th June the BT Openreach engineer came to my house to investigate.
Up to 27th May @ 16.56 hrs I had no problems whatsoever.
Message posted on 24 Jun 2026 01:32 PM
It does sound like an external cable problem so you'd need Openreach to look at it.
As for your use case, if you are supposed to be on call 24/7, your employer should really be paying for a business line for property. Running such an important service over a domestic Sky broadband line is not ideal.
